What is "d" in slab wizard
Hi
In the above image, what is the d (not enterable) ?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
"d" is diameter of support, defined as circular column
Krzysztof Wasik
Okay, but why does it get defined if I give b and h dimensions?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Anonymous
Once it is inactive for rectangular support just ignore it. O,2 seems to be set as default for all dimensions.
Krzysztof Wasik
Thank you Krzysztof.  Accepted as solution.
