Weld connection
Weld connection
Message 1 of 1
Weld connection
Hello everybody,
I am contacting you because I don't understand where some data from the assembly calculation come from.
I would like to know the formulas that make it possible to calculate the stress in a vertical weld, the normal stress in a weld and the tangent stress.
The data are below and I've attached you the robot file.
Thank you for the answer.
Kind regards
Aw =
14,29
[cm2]
Area of all welds
[4.5.3.2(2)]
Awy =
9,38
[cm2]
Area of horizontal welds
[4.5.3.2(2)]
Awz =
4,90
[cm2]
Area of vertical welds
[4.5.3.2(2)]
Iwy =
164,73
[cm4]
Moment of inertia of the weld arrangement with respect to the hor. axis
[4.5.3.2(5)]
s^max=t^max =
11,86
[MPa]
Normal stress in a weld
[4.5.3.2(5)]
s^=t^ =
10,12
[MPa]
Stress in a vertical weld
[4.5.3.2(5)]
tII =
5,06
[MPa]
Tangent stress
[4.5.3.2(5)]
bw =
0,80
Correlation coefficient
[4.5.3.2(7)]
Ö[s^max2 + 3*(t^max2)] ≤ fu/(bw*gM2)
23,73 < 365,00
verified
(0,07)
Ö[s^2 + 3*(t^2+tII2)] ≤ fu/(bw*gM2)
22,06 < 365,00
verified
(0,06)
s^ ≤ 0.9*fu/gM2
11,86 < 262,80
verified
(0,05)
Replies (0)
