Walls Buckling Analysis
faisal.aaouatif
faisal.aaouatif
Good Morning/Evening
Is there any precaution to take when doing a buckling analysis of a structure having only walls as a structural system .
columns should be divided to a certain number of FE , is it the case of walls ? if yes What are mesh number/size to have in order to have a reliable results ?
Thank you
Rafal.Gaweda
Autodesk Support
Autodesk Support
Use standard meshing options as you do.
Depending on model 0.5 to 1m FEs
Rafal Gaweda
