- Mute
- Permalink
- Report
Hello everyone,
I have the following question (trouble). I have a lot of vertical panels (can name it "walls") which one intersect each other, but doesn't divided in intersection lines (please, see attached image). Of course, in process of meshing I have obtained situation, when there are no common nodes in intersection lines of "walls", thus they are independent from each other.
So, have I any chance to split (divide) them automatically in iintersection to obtain common calculation nodes in lines? Any of program function (magic Rafal's macros/script) exist for this task?
To make thing clearer, I have to say, that the whole task is to calculate waffle slab of quite irregular shape with shell elements. So, I have choose the technology: RST -> RSA. But slab has a lot of elements and right now I'm in process of selecting variants (cell dimensions and other), so manual dividing in both of RSA and RST is appropriate way...
Thank you in advance!
