Wall reaction diagram
saclovitzky
saclovitzky
Is it possible to adjust the size of  reaction diagrams separately to its "description"(ie, wall reaction diagram).
There are times when you want to view the over-all wall reactions of multiple walls, the reaction diagram are quite small.At the moment, you can go to "Display" and adjust the size,the trouble is, both the diagrams and its decription can be both bigger or smaller.I'm just wondering whether you can adjust the diagram and its descrition separately for clarity purposes(pls. see attached screenshot.
saclovitzky
any comment Simau/Rafacascudo?
saclovitzky
Does it mean that no reply on my query meant that it is not possible yet to do this inRobot(wall reaction diagram).
If that's the case, I would like to request to the development  team to have at look at it.
Stephane.kapetanovic
hi @saclovitzky
Have you ever tried using the Page Up and Page Down keys on your keyboard?
You can also try clicking the 'Normalize' button in the 'Diagrams' dialog box, under the 'Reactions' tab.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
saclovitzky
@Stephane.kapetanovic thanks for your reply, I've tried that, but both the diagrams and its description are simultaneously becomes bigger/smaller.
What I wanted,if possible,is to make the wall reaction diagram and its description to be adjusted separately(in terms of size).
Let's wait and see what the development team has to say. It’s true that the + and - keys could be put to better use.
Simau
Hi @saclovitzky
Not possible, 2 options are linked
M. Agayr
