Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Wall fixed support strange moments
6 REPLIES 6
415 Views, 6 Replies
Hi, i made this simple model to understand how robot works....so there is a simple wall with just a fixed support at the base and a Fy=100 kn in the middle. If i take a look at the mxx maps i got this image. I thought that the moment in force application point would be 0...isnt'it? Is the moment in that point caused by the internal reaction? the wall is 4m height and 4m large with 5cm tickness. Thanks everybody, i hoper you could help me
6 REPLIES 6
Artur.Kosakowski
Could you attach your model?
Artur Kosakowski
in reply to: Artur.Kosakowski
yes for sure. Here is my model
Artur.Kosakowski
Mind that the wall works in both directions and it deforms horizontally as well as vertically under the point load. In addition you should correctly set the projection of the results. I'm attaching the results for a model with rigid links defined along the top edge for the comparison.
Artur Kosakowski
I would like to know the deflection on z axis after the reinforcement. But if i use "plate and shell reinforcement" i could not get z axis deflection...How can i get the z axis deflection?
Artur.Kosakowski
By z axes do you mean the local Z of the panel (in the direction perpendicular to the panel) or the global Z (in the panel plane) ?
Artur Kosakowski
i'm sorry i made a mistake because i didn't use a sls combination...
Technology Administrators
