Hey guys. Why I'm i not able to edit dimensions, loads and reinforcement pattern?
Solved by Rafal.Gaweda. Go to Solution.
Solved by Refaat. Go to Solution.
Do you know which Design code is nearly similiar to the danish design code?
It does not matter in this context
Only the one shown above is implemented in Robot for walls.
