Message 1 of 8
08:08 AM
A colleague set out a simple structure with any bar section gamma angles set to zero. Some of the columns seem to have defined a local bar definition differently to other columns of the same type, and as such appear to have a gamma angle applied. This is as in the attached image, with several different versions of local axis as well. Trying to change the bar in the geometry>properties>local bar direction seems to work some of the time. I would like to know if others have come across this, why it happened in the first place and if there is a way to prevent it?
