Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Vessel platform load direction
1 REPLY 1
397 Views, 1 Reply
Hi everybody,
I just model a vessel platform and i found that the load direction on panel is incorrect. can anyone explain me how can i do for it?
and please help me to check my model.
Thank you.
1 REPLY 1
Rafacascudo
They´re all claddings with load distribution one way in panel Local Y direction. You can see below that The local y axis (green) for your panels are not exactly on the radial direction.
You need to align your local y axis with the radial direction using the Local system orientation(for panels) dialog.
But anyway , the loads applied to your claddings will not be distributed correctly to your surronding beams because the arc discretization for your panels and your beams are different.
Try to redo your panels contours based on the surronding beams nodes
Rafael Medeiros
