Hi Guys,
Wishing every one a happy new year
I am trying to extract panel loading data both Planar loadind 3P and also contour method in Robot
I am geeting run-time error 13 Type Mismatch @ hightlighted line if the load type is planar 3P
And No data is extracted if the loading is planar contour 3P
Please help and thanks in advance.
And note I am very new to robot and biginner in VBA.
Private Sub CommandButton5_Click()
Dim robapp As New RobotApplication
Dim projPref As RobotProjectPreferences
Set projPref = robapp.Project.Preferences
Dim Fcoeff As Double, Lcoeff As Double
Dim RU As RobotUnitData
Dim RUED As RobotUnitEditionData
Set RU = projPref.Units.Get(I_UT_FORCE)
Set RUED = projPref.Units.UnitEdition.Get(I_UMT_FORCE, projPref.Units.UnitEdition.Find(I_UMT_FORCE, RU.Name))
Fcoeff = RUED.Coefficient
Cells(2, 5) = RU.Name
Cells(2, 6) = Str(RUED.Coefficient)
Set RU = projPref.Units.Get(I_UT_STRUCTURE_DIMENSION)
Set RUED = projPref.Units.UnitEdition.Get(I_UMT_LENGTH, projPref.Units.UnitEdition.Find(I_UMT_LENGTH, RU.Name))
Lcoeff = RUED.Coefficient
Cells(2, 8)= RU.Name
Cells(2, 9) = Str(RUED.Coefficient)
[D9].Value = "Px1 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[E9].Value = "Py1 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[F9].Value = "Pz1 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[G9].Value = "Px2 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[H9].Value = "Py2 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[I9].Value = "Pz2 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[J9].Value = "Px3 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[K9].Value = "Py3 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[L9].Value = "Pz3 [" + Cells(2, 5) + "/" + Cells(2, 8 )+ "2]"
[M9].Value = "X [" + Cells(2, 8 )+ "]"
[N9].Value = "Y [" + Cells(2, 8 )+ "]"
[O9].Value = "Z [" + Cells(2, 8 )+ "]"
Range("A10", "T50000").ClearContents
Dim RCase As IRobotCase
Dim Simplecase As RobotSimpleCase
Dim recs As RobotLoadRecordMngr
Dim rec_1 As RobotLoadRecordInContour
Dim CaseServer As RobotCaseServer
Set CaseServer = robapp.Project.Structure.Cases
Dim row As Integer
Dim xx As Double, yy As Double, zz As Double
row = 10
'check caseServer.Getall.count works
'Cells(1, 1).Value = CaseServer.GetAll.Count
'End Sub
'Sub Tochck()
'works
For i = 1 To CaseServer.GetAll.Count
Set RCase = CaseServer.GetAll.Get(i)
If (RCase.Type = I_CT_SIMPLE) Then
Set Simplecase = RCase
Set recs = Simplecase.Records
For j = 1 To recs.Count
'IF LOADING TYPE : THE PLANAR LOADING 3P ON CONTOUR
If (recs.Get(j).Type = I_LRT_IN_CONTOUR) Then
'always rec_1 is nothing even the loading is planar contour type
Set rec_1 = recs.Get(j)
Cells(row, 1) = RCase.Number
Cells(row, 2) = j
Cells(row, 3) = rec_1.Objects.ToText
Cells(row, 4) = rec_1.GetValue(I_ICRV_PX1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 5) = rec_1.GetValue(I_ICRV_PY1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 6) = rec_1.GetValue(I_ICRV_PZ1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 7) = rec_1.GetValue(I_ICRV_PX2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 8)= rec_1.GetValue(I_ICRV_PY2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 9) = rec_1.GetValue(I_ICRV_PZ2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 10) = rec_1.GetValue(I_ICRV_PX3) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 11) = rec_1.GetValue(I_ICRV_PY3) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 12) = rec_1.GetValue(I_ICRV_PZ3) / Fcoeff * Lcoeff * Lcoeff
For K = 1 To rec_1.GetValue(I_ICRV_NPOINTS)
rec_1.GetContourPoint K, xx, yy, zz
Cells(row, 13) = xx / Lcoeff
Cells(row, 14) = yy / Lcoeff
Cells(row, 15) = zz / Lcoeff
row = row + 1
Next K
ElseIf (recs.Get(j).Type = I_LRT_IN_3_POINTS) Then
'Error 13 Type Mismatch
Cells(row, 2) = j
Cells(row, 4) = rec_1.GetValue(I_3PRV_PX1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 5) = rec_1.GetValue(I_3PRV_PY1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 6) = rec_1.GetValue(I_3PRV_PZ1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 7) = rec_1.GetValue(I_3PRV_PX2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 8 )= rec_1.GetValue(I_3PRV_PY2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 9) = rec_1.GetValue(I_3PRV_PZ2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 10) = rec_1.GetValue(I_3PRV_PX3) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 11) = rec_1.GetValue(I_3PRV_PY3) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 12) = rec_1.GetValue(I_3PRV_PZ3) / Fcoeff * Lcoeff * Lcoeff
For K = 1 To 3
rec_1.GetPoint K, xx, yy, zz
row = row + 1
Next K
End If
Next j
End If
Next i
End Sub
That happens because that variable should be declared as RobotLoadRecordIn3Points and not RobotLoadRecordInContour.
Private Sub CommandButton1_Click()
Cells(2, š = RU.Name
[D9].Value = "Px1 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[E9].Value = "Py1 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[F9].Value = "Pz1 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[G9].Value = "Px2 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[H9].Value = "Py2 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[I9].Value = "Pz2 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[J9].Value = "Px3 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[K9].Value = "Py3 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[L9].Value = "Pz3 [" + Cells(2, 5) + "/" + Cells(2, š + "2]"
[M9].Value = "X [" + Cells(2, š + "]"
[N9].Value = "Y [" + Cells(2, š + "]"
[O9].Value = "Z [" + Cells(2, š + "]"
Dim rec_2 As RobotLoadRecordIn3Points
Dim row As Integer
row = 10
'End Sub
'Sub Tochck()
'works
Cells(row, 2) = j
Cells(row, š = rec_1.GetValue(I_ICRV_PY2) / Fcoeff * Lcoeff * Lcoeff
row = row + 1
Next K
Set rec_2 = recs.Get(j)
Cells(row, 2) = j
Cells(row, 3) = rec_2.Objects.ToText
Cells(row, 4) = rec_2.GetValue(I_3PRV_PX1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 5) = rec_2.GetValue(I_3PRV_PY1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 6) = rec_2.GetValue(I_3PRV_PZ1) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 7) = rec_2.GetValue(I_3PRV_PX2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, š = rec_2.GetValue(I_3PRV_PY2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 9) = rec_2.GetValue(I_3PRV_PZ2) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 10) = rec_2.GetValue(I_3PRV_PX3) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 11) = rec_2.GetValue(I_3PRV_PY3) / Fcoeff * Lcoeff * Lcoeff
Cells(row, 12) = rec_2.GetValue(I_3PRV_PZ3) / Fcoeff * Lcoeff * Lcoeff
For K = 1 To 3
rec_2.GetPoint K, xx, yy, zz
row = row + 1
Next K
End If
Next j
End If
Next i
End Sub
kind regards
