Values not shown in the Envelope table
mdesjardinsXJ286
Message 1 of 8
mdesjardinsXJ286
I am looking at the enveloppe of forces on my project. Moment value are not shown in the table but are shown on the diagram. How can I fix that so I get all the max and min value for every type of effort on the envelope table.
See those screen shot as an example. I should see valu around 5kNm for My in the enveloppe table but it show only 0.
I would like to be able to check just by looking at the envelope table without being worry that some value don't show up.
File is attached
Replies (7)
Message 2 of 8
Stephane.kapetanovic
hi @mdesjardinsXJ286
your bars are not divided, so you need to add division points to your results
https://help.autodesk.com/view/RSAPRO/2026/ENU/?guid=GUID-65144A8E-58BE-4316-B29D-72D1C7985A2D
Best Regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 3 of 8
mdesjardinsXJ286
Great thank you it worked.
But I have a question does this mean that ROBOT will show result only at nodes? What if the max effort is between two nodes? Will it show on the envelope table?
Is there anyway to set forces table to be 100% sure I get all maximum for every member (Fx,Fy,Fz,Mx,My,Mz) no mather where it happens along the member?
Message 4 of 8
The tabulated values are provided only at the selected points.
Calculating the maximum simultaneous forces across all positions on the beam is resource-intensive and could make it harder for users to interpret results.
You should refer to the result curves, assess your specific needs, and select the points accordingly. This is a standard practice in most analysis software.
If you're looking for tools better suited to your specific study, consider creating a simple Excel program to analyze the maximum tabulated values.
Best Regards
Message 5 of 8
Rafacascudo
When you insert the characteristic points  or other division points as shown in the picture you sent , it should appear on the table automatically
Rafael Medeiros
Message 6 of 8
mdesjardinsXJ286
ok thanks,
An other basic question. Can we add a filter per section type or per group when we are viewing results on the diagram. So for example only the cable apear or only the wood plank or a specific part of the structure I want to study?
Message 7 of 8
Rafacascudo
Select the bars you want and
1-on View/Display mark to "display only to selected elements"
or
2- Click on " Edit(open) in another window" icon
Rafael Medeiros
Message 8 of 8
mdesjardinsXJ286
Hi guys,
I divided my bars in 2 to get the results for the moment in the middle of the planks. When I run the analysis a combination that was converging before is not converging anymore (Case 23 only others are normal because of boundary condition). Do you have an idea why? Is my division node changing the result of the analysis ?
Before
After
I generated the nodes with the parameter below.
Regards and thanks again for your help
