Exact Deformation for Members Inconsistent Max Defeormation
umut.akparlar
umut.akparlar
I want to use SLS envelope max deformation for members, but the GUI shows a different max deformation from the members.
The diagram description shows max. 25.067, but the GUI shows max 24.688. I isolated the member to ensure it won't solve this inconsistency.
Could you kindly provide input on this?
Regards
Konrad.O
Autodesk Support
Autodesk Support
Hi @umut.akparlar,
In which version did you encounter this? Could you check this effect in version 2026? We have corrected a similar case. If you still experience this issue, please send me the model.
Konrad
Konrad Ociepka
Senior Product Owner - Structural Analysis
umut.akparlar
Thank you @Konrad.O
I was using RSA 2025. I don't see the same issue with RSA 2026. It is probably a SW bug.
