Values Being Displayed in Simulation Report
eric
Message 1 of 1
eric
As can be seen in the image below, I generated result report for my cases.
All value are ok except the precision value for Fx (kN) in case 4 and case 5, those two values becomes “####” and I tried the below changes and the problem remains the same.
  1. Adjustment on the width/space of that column.
  2. Increasing/decreasing the decimal places to max and min.
  3. Re-simulate the system.
  4. Restarting the RSA software.
  5. Slight change the input value and re-simulate the system.
All other values look fine but these two values, I believe the actual value of “#####” is ok as well; however, my client would want a clear and exact report.
Could you please kindly advise the situation?
Replies (0)
