Using the French kit RSA expert
faisal.aaouatif
Message 1 of 15
faisal.aaouatif
Unable to use (install ok ) the french_country_kit_for_autodesk_robot_structural_analysis_expert_2012_2 even if im on RSA2014...
see attachement
Help needed please.
Accepted solutions (3)
Replies (14)
Message 2 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
You missed the attachment.
Is that that you have Robot 2014, Robot 2012 and Robot Expert 2012 installed  and you can work with Robot 2014, Robot 2012 but not Expert 2012?
Artur Kosakowski
Message 3 of 15
faisal.aaouatif
sorry ;
it seems that i cannot add attachement ??.
anyway Products in this machine :
RSA 2013 and  2014 installed and worked
CBS 2013 and CBS 2014 installed and worked
Spreadsheet Calculator 2013 installed and worked
Spreadsheet Calculator 2014 installed but only get blank page at openning ( 33sheet11 )
Expert 2012 installed but not working on full mode ( only demo )
System XP Professionnal 64 bit.
Thank you
Message 4 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to zip it.
Have you downloaded and installed the Content from the Subscription site?
You should receive a separate message for  this topic. Please let me know if the solution I proposed worked for you.
Mind that XP is no loner officially supported for v.2014
Artur Kosakowski
Message 5 of 15
faisal.aaouatif
Thank you Artur ,
The reinstallation of the French Kit by the .msi afforded solved the problem Smiley Happy.
Is there a solution for Spread sheet calculator 2014 ?
What is the recommeded system for Autodesk Products ( Premium Building suite 2014, RSA2014 ) ?
Thank you
Message 6 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
To be honest based on the description you provided I'm not sure what the actual situation is. Are you able to open and use one of the provided modules selection it from the tree? Mind that the content of SC2014 is in fact the same as SC2013.
Follow the recommendations for Revit. Robot is less demanding Smiley Happy
Artur Kosakowski
Message 7 of 15
faisal.aaouatif
Good Morning / Evening Artur
This point was that there is only a blank worksheet loaded, with no tree of modules.
I Have just reinstalled the product and things got Ok.
Thank you very much
Message 8 of 15
faisal.aaouatif
Hi Artur ,
ive upgraded my machine from XP64 to Win7 64 , but when i downloaded the Expert module from my subscription account and install it successfully ,  it dosent work.
thanks for help.
Message 9 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is there any message displayed?
Artur Kosakowski
Message 10 of 15
faisal.aaouatif
Hi Artur
See attachment please.
Thank you
Message 11 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check if you have C:\Program Files (x86)\Common Files\Autodesk Shared\EXPERT 2012\EXPERT BA\R_PATHS.CFG file on your computer. If yes, send me this file. If not, try to uninstal calculators again, delete the EXPER2012 folder and install calculators once more.
Artur Kosakowski
Message 12 of 15
faisal.aaouatif
Following the path youve indicated , there is no Expert 2012 folder.
What ive got in folloiwing folder  " C:\Program Files (x86)\Common Files\Autodesk Shared " is :
\Structural .... and
\Uninstall toll ....
BUT , the Expert Folder is located in the following Path : " C:\Program Files (x86)\Autodesk\" which contains folders named :
EXPERT Assemblages Bois            :   C:\Program Files (x86)\Autodesk\EXPERT\EXPERT Assemblages Bois
EXPERT BA                                          :   C:\Program Files (x86)\Autodesk\EXPERT\EXPERT BA
EXPERT EC3                                       :   C:\Program Files (x86)\Autodesk\EXPERT\EXPERT EC3
EXPERT EC4                                       :   C:\Program Files (x86)\Autodesk\EXPERT\EXPERT EC4
EXPERT Murs de Soutenement       :  C:\Program Files (x86)\Autodesk\EXPERT\EXPERT Murs de Soutenement
EXPERT Pieux                                     :  C:\Program Files (x86)\Autodesk\EXPERT\EXPERT Pieux
EXPERT Sections de Pont                : C:\Program Files (x86)\Autodesk\EXPERT\EXPERT Sections de Pont
All theses folders contains a file named R_PATHS.CFG
Would you like me to send you the one related to "Expert Assemblage Bois" and the other related to "Expert BA" or all of them ?
Thank you.
Message 13 of 15
Artur.Kosakowski
Autodesk Support
Autodesk Support
Replace R_PATHS.CFG file from C:\Program Files (x86)\Autodesk\EXPERT\EXPERT BA with the attached one. Mind that you have to run Explorer as Admin.
Artur Kosakowski
Message 14 of 15
faisal.aaouatif
Great.
It works
Thank you Artur
Message 15 of 15
where can i download this RSA expert kit? it's good for wooded asambles?
