We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
User reinforcing database and required reinforcment
Romanich
Mentor Mentor
Romanich
I made my own database of reinforcement bars and when used it I see this:
As I know from SDK Kit, Robot uses method to obtain diameter from area of required reinforcement. So, question is - maybe uses of BarSize field data (or DiameterReal) will be correct than this one ?
In provided reinforcement all correct.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure if I understand you correctly. Is the objective to have 2f14.8 and 4f23.2 in the reinforcement table?
Artur Kosakowski
Romanich
No, objective is to have 2f16 and 4f25 in the reinforcement table.
Roman Zhelezniak
Romanich
Artur, for example, I've used non metric ACI RC code and ACI reinforcing database:
Roman Zhelezniak
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm sorry but the currently the values displayed in these fields are generated with use of the different tool and not taken from the indicated field of the bar database.
Artur Kosakowski
Romanich
Can you add this issue to Wishlist?
Roman Zhelezniak
Artur.Kosakowski
Autodesk Support
Autodesk Support
I have already done this. I always do Smiley Happy
Artur Kosakowski
