User defined (via API or any method) maps on bars. Steel design. Utilisation rat
I need to do some steel analysis with an historical Steel code ('50s), therefore the steel design module in Robot cannot perform it.
I will do the calculation outside of Robot, but I would like to map back in Robot the governing utilisation ratio with colours.
Is that possible?
Any method (API, combination of manual input and API...) would be fine.
Any ideas?
Many thanks!
VMA
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I am sorry but it is not possible to put \ pull back any results to Robot, neither manually nor  by API.
Rafal Gaweda
Thanks Rafal for your quick reply.
I have found a way to post my calculation results into Robot manually (see attachments):
- I assign the utilisation ratio to the bar name
- I create groups for each utilisation ratio range and I assign them a colour, ie "UR>1.0", red.
In Display>Mark by colours > Tick Groups
plus Display> Bars > Tick Bar name
Can you do this via API? Do you have any examples on how to do it?
Many thanks,
Violeta
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Oh, this way it could be possible by API.
While creating the group color can be assigned.
Also display should be available (I_VDA_STRUCTURE_GROUP_COLORS)
Never tried by myself 🙂
Rafal Gaweda
Romanich
Hi @Anonymous
Please note that you will have only 11 colors for your groups.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
