User-defined material properties
paul.hillCU7HG
Observer Observer
paul.hillCU7HG
Observer
Observer
I have been working with a model which was set up on another computer, and has user-defined material properties, which I would like to use on new models.  The other computer is to be decomissioned soon.
I understand the philosophy from Autodesk to link the user-defined properties to the originating PC - but can anyone tell me the file path/file which I could copy onto a new PC to save the user-defined material settings?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Cfgusr (configuration files, RGL files)
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 201x\CfgUsr\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 201x\CfgUsr\
Win 7 32- or 64-bit RSAPro:
user section databases, material databases, etc.
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\201x\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\201x\
Artur Kosakowski
paul.hillCU7HG
Observer
Observer
Many thanks for your response.
For the benefit of any other users, I am using Robot 2015 on Windows 10, and the specific file which appears to hold the material properties is \RMAT001.xml
Artur.Kosakowski
Autodesk Support
Autodesk Support
The number corresponds to the international dialing number of the country you selected material database for e.g. 001 USA; 044 UK; 033 France etc.
Artur Kosakowski
