online help does not working
online help does not working in Robor 2017 when pressing help buttom. Empty web browser appears.  Any ideas?
Thank you.
Frank
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to change the address to:
http://help.autodesk.com/view/RSAPRO/2017/ENU/
Artur Kosakowski
Thanks, It works now. But true is, that it is not user friendly, as I have to do every time I click on Help button. There were not issues like this in previous Robot versions.
Artur.Kosakowski
Autodesk Support
Autodesk Support
The default address the Help command in RSA 2017 redirects you is wrong and this needs to be corrected. I have already notified the right team after reading your post.
Artur Kosakowski
Artur.Kosakowski
Autodesk Support
Autodesk Support
Should be OK now.
Artur Kosakowski
