User Defined Automatic Load Combinations
Babak.moussavian
Babak.moussavian
There are 7 different live loads in the attached model, load case 4 through 10.
I have created a user defined load combination based on Eurocode as per 6.10 C (GEO) which is attached.
STR-GEO Sett C.rgl contains user defined subnature.
I want to make following load combinations:
Combination of Load Cases 4 and 5:
  • Load cases 4 and 5 can be combined with load cases 7 or 8 (or both, or none).
         Load cases 4 and 5 cannot be combined with each other (they cannot act simultaneously).
Combination of Load Cases 9 and 10:
  • Load cases 9 and 10 can be combined with load cases 7, 8, or 6 (or any combination of these, including none).
         Load cases 9 and 10 cannot be combined with each other (they cannot act simultaneously).
I have made 4 groups for live loads shown below:
Furthermore, I have defined following relationships between groups, but I see that live loads 4 or 5 are combined with live loads 9 and 10!
I would appreciate if someone can help me to create all possible valid combinations based on the defined groups and constraints.
Regards
B.M.
CaioSaporito
Hi @Babak.moussavian!
Check if this rule can solve your problem:
I first focused on the groups that you don't want to combine (or EXCL), then just put the rest as "or incl".
Best regards,
Caio
Babak.moussavian
Hi @CaioSaporito!
Yes, it solved the issue. I could make 83 combinations as my preference.
Thanks for your help.
Regards
B.M.
