Remove Fillet Between Panel Edges
teixeiranh
teixeiranh
What is the fastest way to remove a fillet between 2 panel edges?
For example:
90º corner -> applied a 2,00m radius fillet between edges via "Geometry -> Objects -> Fillet".
How can I remove the 2,00m radius fillet and go back to the 90º corner?
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Stephane.kapetanovic
hi @teixeiranh
It may not be the fastest, but my proposal will have its place on this topic.
0 - Move the mouse over the panel.
1 - Click on the panel to select it.
2 - Access the panel or cladding geometry.
3 - The Contour - Tabular Edition appears.
4 - Click on the table icon.
5 - The table is displayed.
*6 - Right-click to display the popup menu.
*7 - Choose "Table Columns." to add columns
*8 - The display parameters dialog box opens.
*9 - Choose "Fillet" and click "Ok."
10 - The additional column is displayed.
11 - Replace the values with 0 and press Enter (the previous value disappears).
12 - Click "Ok" to validate the changes in the table.
Finally, validate the changes in the panel by pressing "Apply"
(*) Steps 6, 7, 8, 9 no longer need to be performed on the same project
Best Regards
Note that this topic also covers "Tips and Tricks in Robot."
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
teixeiranh
Probably the fastest, thank you.
