upper flange fully restraint
danielrmc1726
danielrmc1726
hello iam trying to design a group of beams, this beams will support a concrete slab and i need to consider the top flange fully restrained, but when i add the position of the bracings there is not any change in the effective lenght of the beam, am using AISC 2016 CODE.
i will appreciate any help
thanks!
danielrmc1726_0-1641577931091.pngdanielrmc1726_1-1641577990087.pngdanielrmc1726_2-1641578079574.png
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @danielrmc1726
Member critical point is at its begining. Bottom flange might be compressed in that point.
Krzysztof Wasik
danielrmc1726
the beams are released at ends (simply supported) so the bottom flange is in tension in all the lenght,  that´s why i want to restrain the top flange , correct me if iam wrong.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @danielrmc1726
As far as I can check in your screenshots, Steel design calculation note shows negative My moment.
according to sign convention in Robot it suggest compression in bottom flange.
Krzysztof Wasik
