Updating model support spring stiffness using C# API
josepht21
josepht21
Hi everybody,
I am trying to update the springs of the model using the API, I need the model to update inside Robot and run the analysis again (an older model will be on with its results already). What is the best way to do this? C# code examples would be great to get if possible! Also, is it possible to close and open Robot in a loop, for example run the analysis and then close Robot and immediately after that open a new one?  Thanks in advance!!
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @josepht21
Everything what You wrote it possible to be made using API.
Rafal Gaweda
