Uniform planar load
Uniform planar load
tarmoroos2554
Uniform planar load
tarmoroos2554
Hey !
How can I add projected "uniform planar" or "planar 3p" loads to panels marked in the picture ?
Can You insert projected load in Global Coord. system only ?
Thank You !
Try the process shown in the picture for adding Planar and 3P loads.
Yes you can also insert load in local coordinate system.
Artur.Kosakowski
Autodesk Support
Autodesk Support
The direction of the load should be local Z (instead of the global ones). The direction of the load will correspond to the direction of the local z axis of the panel (to reverse it use either negative or positive load value or change the orientation of the local z axis of the panel). The projected load is to be used for snow.
Artur Kosakowski
