Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
Did you mean:Ā
Uniform moment in bar in local coordinate system with API
4 REPLIES 4
LuisCRodrigues
344 Views, 4 Replies
Hi all,
I'm trying to generate uniform loads and uniform moments in bars with API.
For uniform loads, the member "I_BURV_LOCAL" defines if the loads values refer to the global or local coordinate system.
For uniform moments, it seems we can only create load records in the global coordinate system with API.
Does anyone know how to impose the local coordinate system?
Thanks in advance.
4 REPLIES 4
hi @LuisCRodrigues
here after an example to set local loads (uniform and moment distributed moments)
Sub CreateBarsUniformAndMomentLocalLoad()
  Dim RobApp As IRobotApplication
  Set RobApp = New RobotApplication
  Visible = RobApp.Visible = -1
  IsActive = RobApp.Project.IsActive = -1
  Ready = Visible And IsActive
  If Not Ready Then
    Set RobApp = Nothing: Exit Sub
  End If
  Dim RSel As RobotSelection, AllCasCol As RobotCaseCollection
  Dim Cas As IRobotCase, FirstAvailableCase As RobotSimpleCase
  Dim LoadRecord As IRobotLoadRecord
  Dim RecAT As IRobotCaseAnalizeType
  Dim Bars As RobotBarServer, Bar As RobotBar
  Dim TbForces() As Double
  Dim mtx(0 To 2, 0 To 2) As Double
  With RobApp
    With .Project.Structure
      Set RSel = .Selections.CreatePredefined(I_PS_CASE_SIMPLE_CASES)
      Set AllCasCol = .Cases.GetMany(RSel)
      Set Bars = .Bars
    End With
  End With
  For I = 1 To AllCasCol.Count
    Set Cas = AllCasCol.Get(I)
    RecAT = Cas.AnalizeType
    If RecAT <> I_CAT_DYNAMIC_MODAL Then
      Set FirstAvailableCase = Cas
      ' Uniform Load
      With FirstAvailableCase.Records.Create(I_LRT_BAR_UNIFORM)
        .Description = "New Uniform Load"
        .Objects.FromText "1 2"
       ' IRobotBarUniformRecordValues
        .SetValue I_BURV_PY, -5000
        .SetValue I_BURV_LOCAL, 1 ' < Local Load 0 = false, 1 = true
      End With
      ' Global Moments
      With FirstAvailableCase.Records.Create(I_LRT_BAR_MOMENT_DISTRIBUTED)
        .Description = "New Distributed Moment Load"
        .Objects.FromText "3 4"
       ' IRobotBarMomentDistributedRecordValues
        .SetValue I_BMDRV_MX, -5000
      End With
      ' Local Moments
      TbBarNos = Array(5, 6)
      For j = 0 To UBound(TbBarNos)
        BarNo = TbBarNos(j)
        Set Bar = Bars.Get(BarNo)
        Bar.GetLocalMtx mtx(0, 0), mtx(0, 1), mtx(0, 2), _
                        mtx(1, 0), mtx(1, 1), mtx(1, 2), _
                        mtx(2, 0), mtx(2, 1), mtx(2, 2)
        TbForces = SetForces(0, 0, 0, -5000, 0, 0)
        Transform TbForces, Invert(mtx) ' To Local
          .Description = "New Distributed Moment Load - Local"
          .Objects.FromText Str(BarNo)
          .SetValue I_BMDRV_MX, TbForces(3)
          .SetValue I_BMDRV_MY, TbForces(4)
          .SetValue I_BMDRV_MZ, TbForces(5)
        End With
      Next j
      Exit For
    End If
  Next I
End Sub
Function SetForces(Fx As Double, Fy As Double, Fz As Double, Mx As Double, My As Double, Mz As Double) As Double()
  Tb = Array(Fx, Fy, Fz, Mx, My, Mz)
  Dim TbForces(0 To 5) As Double
  For I = 0 To 5: TbForces(I) = Tb(I): Next
  SetForces = TbForces
End Function
Function Invert(m() As Double) As Double()
  Dim rm(0 To 2, 0 To 2) As Double
  For I = 0 To 2
    For j = 0 To 2: rm(I, j) = m(j, I): Next j
  Next
  Invert = rm
End Function
Sub Transform(v() As Double, m() As Double)
  Dim vt(0 To 5) As Double
  For I = 0 To 2
    For J = 0 To 2
      cm = m(I, J)
      vt(I) = vt(I) + v(J) * cm
      vt(I + 3) = vt(I + 3) + v(J + 3) * cm
    Next J
  Next I
  For I = 0 To 5: v(I) = vt(I): Next I
End Sub
Best Regards
Tags (4)
Hi@Stephane.kapetanovic
This is a very interesting approach.
Thanks for your help.
msg 2 updated
I understand you corrected how the moments in the local coordinate system are translated to the global coordinate system. I was precisely working in the same direction.
Thank you for your time. This will be very helpful.
It's just a workaround, but the real question is why the API can't set the load as local as it does for others.
To be seen by Autodesk Team? Maybe @Rafal.Gaweda could comment.
Technology Administrators
