Unexpected Mz in beams
Hi friends
I am calculating a steel structure and i am getting unexpected Mz in some members. See capture below
As you see this happens in both slabs. Can anyone help me?
Model attached
Rafacascudo
There´s a rigid link  and acts especially for load 6 Wx transfering the concentrate load to the region where the MZ occurs
If it´s a wind load set it on the panel exterior edges/beams on the facade and let the diaphragm distribute the load more evenly
Rafael Medeiros
Thank you for your answer my friend
But see for example combo 39 (It doesnt include Wx) and there is high Mz too. Maybe is due to Tx and Ty (accidental torsional moments). What do you think?
So rigid link seems to be the problem. But how do i include that nodes (720 and 717) in the diaphragms to get a good behavior of the structure?
Thakns in advance
Simau
hI @Anonymous
Try horizintal bracings on the slabs instead of rigid links.
Why There is no release on secondary bars?
M. Agayr
Rafacascudo
Include nodes 717 and 720 manually on the corresponding Diaphragm rigid link . Look below
   Delete the rigid links you created and let the diaphragm do the job .
   The analysis will give you and instability type 2 for nodes 717 and 720 , but it doesn´t matter as they are isolated nodes that are  there to just load the strucutre through a rigid link.
Rafael Medeiros
Thank you my friend @Rafacascudo
