Unable to run analysis of ground beam
Message 1 of 9
I drew my house's structural drawing in Revit. After that, I sent that model to robot structural for calculating reinforcement needed. After I inserted all the loading and run the analysis for beam reinforcement, it popped out " selected section is not supported, the section will be replaced with rectangular section". When I tried to analysis the ground, Robot itself will automatically shut down. Can someone help me?
Thank you.
@Anonymous Artur Kosakowski marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm sorry for not being able to look at this earlier especially that it seems that it is easy to solve. In Robot you should define section type that corresponds to the design module you want to use so it should be RC Beam rather than RC Column. Try to redefine the sections assigned to the beams.
Artur Kosakowski
Message 3 of 9
@Artur.Kosakowski
Hi, thank you for replying and sorry for late reply.
Unfortunately, it still don't works after I tried your suggestion which is check all the beams details.Do you have any idea what's going on?
Message 4 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the latest version of your model and make screen captures which illustrate the steps to reproduce the issue you are having so that I could try to solve it?
Artur Kosakowski
Message 5 of 9
mustafahesenow
Hi @Anonymous
Just go to Geometry tab then additional attributes then bar on elastic ground
then specify the kz , hy , Hx
then apply on the beams then make calculation and take it to design it will work.
I already tried it on your model and its work .
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 6 of 9
Hi, @mustafahesenow thanks for your suggestion. 🙂 However, I am still not quite sure with your solution because I am the beginner only.
May I know am I at the right track? If so, what value should I input in it? What is the reason of adding the attributes? robot problem 1.1.JPG
Message 7 of 9
Hi @Artur.Kosakowski
I have attached my updated version of my model.
First, I input dead load(-1.5) and live load(-2) into the model. After that, I selected all the beam to run analysis and provided reinforcement. Then It popped out the message " selected section is not supported, the section will be replaced with rectangular section".
Message 8 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try these steps:
Artur Kosakowski
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The situation with very large Z coordinate value has been corrected in HF1 for RSA 2018.
Artur Kosakowski
