Typical rft. problem. Please help.
Hi
1...
I'm trying to use the Typical Reinforcement option to reinforce a beam that is 80*25 cm. The only problem is when i try to add the Additional Reinforcement, it won't let me add 1 rebar, or sometimes it won't let me add 2 rebars. In the first image, i was trying to reinforce that beam, and RSA won't let me add 3 additional bars, it just accepted 5, 10, 15, ... and so (multiples of 5).
Yesterday i was trying to do the same thing to a  60*25 cm beam, and it only accepted a value of 3, 6, 9 (multiples of 3)..
2...
I reinforced 10 columns and 2 beams, the problem is when i update the Revit model, the reinforcement wasn't imported from Robot (after the reinforcing had been done).
I thought maybe the red question mark had to do something about that case. What does that red question mark mean?
Mohammed_Ata
Attach your model, Please
Thanks to you Mohammed for your reply, here is a Mediafire link to the model.
http://www.mediafire.com/file/geqjn1fwqcnv2bu/Robot.rtd
Guys no solution for the first problem ??
Mohammed_Ata
Dear, @Anonymous
You know when you add 4 bottom main bars, you have 3 in between bars distance and when have 6 bars you have 5 spacing and so on !
You already added 6 main bottom bars so, you are allowed to add 5 additional bottom bars or 10 or 15 and so on !
Attached, i added 4 bottom main bars so i expecting additional only 3 bars in the inbetween distances
Understood. Thank you so much 🙂
