Panel reinforcement: panel calculation module does not include finite element
Hi all,
I am modeling an elevated reservoir on ROBOT Autodesk, structure type: building design
Whenever I choose to check the reinforcement of panels (floors/walls), I get the following error:
Panel no. X: The element will not be included in the provided reinforcement modules. The panel calculation module does not include finite element.
Any suggestions? Help?
@Anonymous Artur Kosakowski edited the topic from 'Reinforcement of Panels' for better findability.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Make sure that the panel calculation model is set as shell.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
It worked, thanks!
w04625438HPL8
Community Visitor
Community Visitor
Thank you so much, it works for me also
