I am doing tutorial for Autodesk Robot Structural Analysis 2019 Professional 2019.
When it comes to “Set up the Seismic Analysis” under “Building design” tutorial, I can open file “Structure-Seismic.rtd” but it's blank.
Under preview, before opening this file, I can see a model.
Is it setting problem?
Solved by Rafal.Gaweda. Go to Solution.
Hi @rimutaka
First of all, after opening the model, in the object inspector, is the drawn elements shown or not?!
Try to open it in the repair mode:
or you can upload the file to check (if you want).
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
1. Attached is a screenshot of object inspector after opening the model
2. Opening the model in repair mode has the same result.
