turn off results
turn off results
Message 1 of 9
turn off results
Is there any way to turn off the views with the previously established results without having to go and look for each one and turn it off?
Replies (8)
Message 2 of 9
Rafacascudo
not at once but easier, clicking just on "X" on each window top right , Using menu Window/Cascade or tile horizontally or tile vertically
Rafael Medeiros
Message 3 of 9
rokas_varanauskas
Right-click anywhere on the icon ribbon and select Open layouts from template
Message 4 of 9
Message 5 of 9
Rafacascudo
click on the icon below
Rafael Medeiros
Message 6 of 9
ouoba.diassiboalain
Thanks  !
your solution works
Message 7 of 9
muhamad.mazzaz
Hi, Thanks Rafa, this will works but again it will reset all the view options. is there something else?
Message 8 of 9
Rafacascudo
Try tools/customize/ Open layouts from template. It will revert to RSA defauts layout ,or to your own customized layour if you ,in the same path use "save layouts as template"
Rafael Medeiros
Message 9 of 9
muhamad.mazzaz
Perfect!
