Tunnel with opening and support frame
anthony.rooney7HR29
anthony.rooney7HR29
I am trying to design a tunnel with a opening for access to the side of the tunnel and a frame to support the opening. Is there a different type of analysis i need to use? As linear analysis and standard modeling of the tunnel panels keeps giving the warning of incoherent nodes and the forces are not correctly distributing. Additionally the frame does not appear to mesh correctly to the panels.
Kind Regards,
Anthony
Romanich
Hi @anthony.rooney7HR29 ,
It is hard to say what is going on without having the model. You can zip it and attach to the message.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
anthony.rooney7HR29
I have attached the model, the loading applied is currently indicative however i am just trying to get the model to work efficiently without the load first.
Kind Regards,
Anthony
Rafacascudo
Your center panel with the "hole" has not the same arc discretization as the 2 lateral panels. They have to be identical for the "polygonal" neighbors circles to match..
Also , on job preferences , meshing , do not use/mark kinematic constraints in incoherent points
Rafael Medeiros
Simau
To complete @Rafacascudo 's  comment, the members arc discretization must fit panels discretization.
M. Agayr
anthony.rooney7HR29
Thank you both for the input I will implement these changes.
