Hi there,
This functionality seems to work if i build a model directly in Robot.
if i transfer from Revit to Robot it doesn't. Basically it calculates the load take down diagram, no errors but the tables for the results are empty.
To transfer from Revit to the Robot load take down mode eventually you have to copy and paste the model in the tributary load mode or transfer from Revit in a Robot tributary model where you have just one element, so the model came across.
Do you have any idea to fix this?
Thank you
