Transferring from Revit to Robot shows only axis.
krajad
krajad
When transferring the file from Revit to Robot, for some reason the structure does not appear on Robot. There are no warnings shown during the process. When the Robot software is open it shows only the axis and no structural member. This is just an example that I have provided. I am working with Revit 2023.
Romanich
Hi @krajad ,
Do you have an analytical model defined in your Revit model?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
krajad
Hello @Romanich ,
It appears that I do not have. It shows nothing when I press Analytical model on 3D views.
Romanich
Hi @krajad ,
The Revit-Robot workflow has been changed in 2023 version:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/2023-robot-to-revit-integration/m-p/1...
https://forums.autodesk.com/t5/robot-structural-analysis-forum/reinforcement-from-rsa-to-revit-what-...
You should create an analytical model either manually or using the dynamo plugin available in Revit 2023.
Roman Zhelezniak
