Transfer RSA file in Revit
Message 1 of 14
I have some problem to transfer my Robot structural file into Revit.
Can someone help me??
Thank you
Replies (13)
Message 2 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to change the Robot language to English and then export your model to Revit.
Artur Kosakowski
Message 3 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 4 of 14
Hi, I tried to again to integrate my RSA model in Revit and when  I changed the language to English and then Windows tried to configure Revit structure to finally send a error report and shutdown. I contact Brondon to help my and he did not find the problem. Can you try to help my to transfer it because I think my computer is not enough strong...
Thanks a lot for your help!
Olivier mathieu
Message 5 of 14
Hi Olivier,
I was able to transfer your model into Revit 2016 but some of your beams (e.g. 72DLH14) give me errors as I cannot seem to transfer them over to Revit. Are they custom made sections? I am unsure how Revit would be able to understand those sections.
This is what I see in Revit:
Message 6 of 14
Hi omusafer,
Thanks for your fast response
I thinks thans Revit don't support to transfer some joist and I took them from RSA and they are not custom
Could you send my the model you sucessfully transfered to Revit whithout the joist?
I appreciate what you have done for me
Olivier
Message 7 of 14
You're very welcome Olivier,
Please find the attached model on this post. I have also attached a .txt file showing the errors I get after the transfer for your reference.
Message 8 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
You need to load joists families to a Revit project from US Metric and Imperial Structural Framing catalogs before importing RSA model where they are used as pointed out in one of the previous answers.
I'm atatching the model with joists.
Artur Kosakowski
Message 9 of 14
Thanks a lot Artur !!!
Have a nice day
Message 10 of 14
i got the same problem as olimath96 so i decided to delete all my joist, also i put revit and RSa language in english but after i dont know what to do to tranfer my file ?
can u help me please ?
thank you
Message 11 of 14
I have the same problem as everyone, I put RSA and revit in english, but he doesnt seem to reconize my bar... Can someone help me?
Message 12 of 14
Message 13 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Is it (again) the same file as in http://forums.autodesk.com/t5/robot-structural-analysis/integration-robot-to-revit/td-p/6240327 and http://forums.autodesk.com/t5/robot-structural-analysis/problems-whit-integration-of-rsa-folder-to-r... ?
If so, please do not post the same message in number of topic as it is hard to follow all of them to understand the current situation. Thank you.
Artur Kosakowski
Message 14 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach your Robot model?
Artur Kosakowski
