No, there is not as the values are calculated in nodes and elements centers. You could make some estimation based on area of surface element (provided it is square) as well as area of reinforcement in its center (assuming that this value is similar to the values in this element's nodes) exporting the reinforcement table to Excel if such approximations is acceptable. Otherwise you need to check the values for each of the panel or group of panels designed together in the RC Slab Provided Reinforcement module.
Artur Kosakowski
