time history analysis definition
ACh_D
ACh_D
hi,
i am trying to define a time history analysis but the function is never available in the function tab. modal analysis has been set previously.
is there any limitation of this with the educational version of the software? i have follow every possible tutorial and none is working even on new file
file attached if someone can take a look it will be very much appreciated. if it is not working, what alternative solution do I have, I want to floors acceleration due to wind?
thanks
ACh_D
It is fixed, woud like to write the solution but I have no idea what changed, though I have no results, any idea?
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @ACh_D
You have not defined time function and not assigned it to selected (static load case).
Refer to the following tutorial (time about 18 min)
https://www.youtube.com/watch?v=fRnmamjZbUw&list=PLY-ggSrSwbZqow_60fiqJwS69mg1nQMzk&index=13.
Refer also to modified model.
Krzysztof Wasik
