Time dependent Conrete properties
mustafahesenow
mustafahesenow
Hi All,
As we know that concrete properties will change during the time.
Its related to creep and shrinkage which will affect the modulus of elasticity during this the considered time which is will cause significant changes for high rise building when we check the column shortening.
Is there a way to consider this in times of analysis of concrete structure in Robot.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Replies (8)
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi Mustafa,
No there is not such possibility. Such time effect are not considered.Smiley Sad
For shrinkage you may consider the use of temperature load (uniform cooling TX) if such approximation is acceptable.
Artur Kosakowski
alfredmx
Hello mustafahesenow,
For calculating redistribution of internal stresses (mainly due to creep) in prestressed concrete bridges we have successfully used EN1992-2 Annex KK formula.
Sf=So+(Sc-So)f
in which
Sf=final stressed
So=stresses from construction stages
Sc=stresses assuming the structure is built in one and all permanent loads are applied at the same time
f=factor that depends on final creep coefficient, loading time and aging factor
Results using above formula and those obtained by software that considers explicitly time-dependent concrete effects are in good agreement. The process however becomes complicated because unfortunately RSA phases is very limited, so you have to extract results from individual models and do staged analysis externally. Never tried this approximation in building construction as this effects are usually not considered.
mustafahesenow
Hi @alfredmx
I had checked this formula for high rise building and it is giving wrong results.
Any way thank you so much for help.
Mustafa Hesenow
LinkedIn
mustafahesenow
Hi @Artur.Kosakowski
These changes in concrete is related to to time and concrete age.
Material non-linearity was one of the most big problems to RSA.
I really dont know why Autodesk doesnt develop RSA in a good direction.
Since 2010 the only changes on RSA aside analysis is DAM method and wind simulation where Robobat before had every year many new things .
Mustafa Hesenow
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
Thank you for your comments - I have forwarded them 'higher'.
I'd love to see many new options in every new released version too Smiley Sad
Artur Kosakowski
mustafahesenow
Most of the softwares which was nothing compare to Robot having this type of analysis and since long time
Take a look on (Etabs , Midas , Sap , Staad ,,,,,, etc )
Check the Ideas forum  a lot of Ideas requested and many versions of Robot having very minor changes I really hope to know why like that .
Mustafa Hesenow
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @mustafahesenow
First of all I'd like to thank you for posting your very valuable ideas and your tremendous participation on this forum however I may not be the best person to answer this type of questions. I'm the first one to vote for them and I'd love to see them being implemented but as a part of the Autodesk Tech Support Team I'm not in the position to make this happen. I hope the development team will consider them in the future.
Artur Kosakowski
mustafahesenow
Thank you so much my friend.And I really understand and appreciate all what you said.
But in the other hand.This is our software and its our community which is handled by Autodesk .
You may cant answer our questions but you may transfer this talk to Autodesk and then tell us  what their plan. Or If couldn't we need to know
how can we talk to Autodesk and discuss with them this issue .
Mustafa Hesenow
LinkedIn
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
