Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
timber verification helped with corrupted database
13 REPLIES 13
Message 1 of 14
744 Views, 13 Replies
Dear Artur,
I m struglling  to verify timber structures after  you made the tuturial. I find robot  timber section verification became no userfriendly. when you created last time  you step by step  procedure, you  skipped many steps.  when I used to use Robot Millenium i didnt have these types problems when verifying timber  elements. can you please correct my model.can you help me with:
                           1) the current  section are timber C16, if are not adequate section  can you verify for timber grade C24 IF still fails,i may propose the use   or steel beam and   rectangular  hollow sections for the  posts.
I am doing an structural  assessment if you can help me  by creating a proper steps by step procedure how to avoid  CORRUPTED DATABASE .your help always appreciated.
Thank you
Ernesto
13 REPLIES 13
Message 2 of 14
Rafal.Gaweda
Dear Ernesto
It is not possible to run timber design in your model because there are no member types assigned to bars
PLease look firts at steel design webinar (timber design is very similar)
Example video (I did not play with design parameters, just used default ones to show you design philosophy)
Rafal Gaweda
Message 3 of 14
in reply to: Rafal.Gaweda
Dear Rafal,
Can  you upload the model you  corrected please.  can  you also send me the link of the webnair ur mentioned it. However, it would be great if you or Artur ellaborate stept by step procedure pdf . we have Robot Licence in Office but at the moment  I m pretty much usign my own spreadsheet to verify timber elements.When I used Robot Millennium I didnt encounter these sort of problems.
Thank you very much Artur/ Rafal
Ernesto. Cornwall
Message 4 of 14
DennisVDijk
Hello Ernesto,
I have looked at your model and made it work, see attachment.
First i selected the beams and assigned them to a Member type: Timber beam, see screen. I did the same for the columnssigned.
I combined bar 2 and 4 to a supermember (bar 10) and assigned Timber column auto.
Good luck!
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
Message 5 of 14
in reply to: DennisVDijk
Thank you/Merci Dennis,
  however still  waiting for Artur or Rafal  to reply about previous message
Message 6 of 14
Rafal.Gaweda
Message 7 of 14
Thank you Rafal.
Regarding  API and  excel  using ESOP. further my conversation  with Artur.I was told that you are specialised  develeping API .
Can you please:
  1:  refer me to API tutorial  for Beginners either pdf files or videos links either here or in AUTODESK University website
  2: ellaborate a PDF tutorial on robot spreadsheet calculator(the below  video by Tomaz Fudala) just gives an overview on spreadsheet calculator which no enough at all.
3.does Robot spreadsheet calculator  work within excel 2007 and 2010 only?
4 or perhaps  you with Artur and Tomasz can creat a webinar about how to use efficiently robot spreadsheet calculator:
Robot Structural Analysis 2011 - Spreadsheet Calculator - Part 1
https://www.youtube.com/watch?v=cjxVZrapj_E
Ernesto- Cornwall -England
Message 8 of 14
Rafal.Gaweda
Can you please:
Robot API documentation, examples, tutorials are installed as Software Developer Kit (SDK) installation toghether with Robot from INstall Tools &
Utilites,  or directly from media: \x64\Tools\RSASDK
See next webinar on 18.11 : "Results Connect , Robot API, Dynamo"
Open sheet, fill data or import data from robot, look at results
Yes, 2007, 2010 - both 32 bit.
Not planned
Rafal Gaweda
Message 9 of 14
Thank you Rafal,
Regarding  the  excel version.
 3:we have installed excel 2013.
it seems  the calculator doesnt work  in excel 2013?
4: no planned:
it would be great and helpful for customer if you guys create a webnar  only for spreadsheet calculator. the information or the videos available too little . in the french  version forum they have developed  more than in the english version .
Thank you
Message 10 of 14
Rafal.Gaweda
As I wrote before - it does not work on Excel 2013
Rafal Gaweda
Message 11 of 14
why doesnt work on excel 2013? or  are developing an   add in to link to  excel 2013?
question 4: no planned webinar?
thank you
Message 12 of 14
Rafal.Gaweda
It was developed years ago before developing Excel 2013 by Microsoft
No plans for having it for Excel 2013.
WHat is ineteresting in it to make webinar for it?
Just start it, load any sheet you want, fill data like in Excell in cells with blue texts - that's all.
Rafal Gaweda
Message 13 of 14
Hi Rafal,
 in practice  sometimes   we need to adjust to what we have in office.   for me I would install EXCEL 2010 OR 2007 but in the office they want us to work on excel 2013.I told them  Robot excel spreadsheet work on excel 2010 and 2014
. Regarding webninar.
of course i could play around with  it  but  we have time constraints at the moment. the prupose of a webinar is to give a better insight how to  optimise your time( I  USED FOR A WHILE THE FRENCH VERSION ESOP 2003 at the time ROBOBAT cALLED rOBOT MILLENIUM AND THEN FRENCH COMPANY OWNER OF ROBOT  MILLENNIUM USED TO  PROVIDE USEFUL  EXAMPLES ON  ROBOT SPREADHSEET DEVELOPMENT but now it outdated). I think as customer we  looking for that. i say Tomas Fudala  video    is pretty much limited i think he  keeps as secret it  that which shouldnt be that the case
Message 14 of 14
Rafal.Gaweda
NO, NO, NO
This is not developed anymore and it will not work on any excel 64 bit  and any Excel 2013, 2014 or any newer.
Rafal Gaweda
