The theory Stresses => Momen
Hey. I is results soild.
please provide theory Stresses xx or (Stresses yy,zz) => Momen xx or (Momen yy,zz)
Thansk
Artur.Kosakowski
Autodesk Support
Autodesk Support
For solids bending moments are not available directly. You need to calculate them manually based on stresses e.g. for simple bending design situation first get tension/compression force distribution in the cross section (stress = force / area) and then based on the distribution find bending moment as arm of equivalent forces.
Otherwise try to create a shell model instead.
Artur Kosakowski
Excuse me but.. What was the question all about? Can you explain?
Thank Artur
To levgen
When results stresses of soild => results Momen
