The "calculation option" for beam design is not working
Message 1 of 10
@Anonymous.kosakowaki. thanks for the other day, please I need another help, this time on reinforce concete. The "calculation option" for beam design is not working. Even after saving "save as", the default parameters are still showing up in the calculation note. Please any solution to this?
@Anonymous Artur Kosakowski edited the topic for better findability
Replies (9)
Message 2 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm not sure if I understand you correctly. Could you make screen captures that illustrate what you change and what the result is? Which version of Robot have you got installed (Help > Robot information)?
Artur Kosakowski
Message 3 of 10
@Artur.Kosakowski please kindly find attached. from attachment 1, the calculation option where fcu is 25 mpa was saved as "MOCPEDZ" and the ok button was clicked, but as you will notice from the calculation note picture 2, the concrete data did not change, am still havin fcu as 30.2 mpa.
Message 4 of 10
please find attached in .jpg format.
Message 5 of 10
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 6 of 10
@mustafahesenow yes i know that it not not yet applied, and my question is why was it not applied? after saving and clicking ok. i believe it should be applied to it after saving and clicking ok. i have checked the material settings which is still bs8110, code design setting still bs8110, but when i click ok on the calculation option, it will not apply, i don't know why.
Message 7 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach your rtd file and CfgUsr folder?
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 201x\CfgUsr\
Artur Kosakowski
Message 8 of 10
thanks @mustafahesenow, i just tried changing it manually and it work. thanks i appreciate.
Message 9 of 10
@Artur.Kosakowski, thanks, the idea of @mustafahesenow is the solution. thanks
Message 10 of 10
