The element exceeds geometric limits of the story
Message 1 of 8
After I assign manually the story of my columns, I get this error: The element exceeds geometric limits of the story.
If I let it assign automatically, I get: The element is not assigned to any story...
What gives?
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check which element and assign it manually.If it is longer \ higher than defined  \ assigned story you will get that message about exceeded geometric limits.
Rafal Gaweda
Message 3 of 8
The problem is that I have columns that stretch over 3 stories, and I can't seem to assign them manually to any of those stories without getting this error message (red one, not ignorable):
"The element is defined outside the geometric limits of the assigned story"
The only way for this message not to appear is to define automatic story to those columns...
Is there any other way?
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Ignore it = disable automatic verification in job preferences
Split  columns to "stories" bars
Rafal Gaweda
Message 5 of 8
ok, using the divide command? dividing by a plane?
Message 6 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes
Why not, or different option of divide
Rafal Gaweda
Message 7 of 8
worked like a charm!
thanks
Message 8 of 8
muthomimunyua
Steps:
1. Disable Automatic verification in 'Job Preferences'by going to the 'Meshing Option' then uncheck 'kinematic constraints in incoherent points'.
Muthomi Munyua
