The admissible deflection value has been exceeded for panel
Victor_Huang1
Victor_Huang1
Hi All,
I am modelling a panel retaining wall and got the admissible deflection value has been exceeded problem.
Please find the model attached.
Any idea how I can fix this problem?
Thanks.
Regards;
Victor
Victor_Huang1
Any help would be appreciated!!
DennisVDijk
Hello Victor.Huang,
What do you mean by "and got the admissible deflection value has been exceeded problem"
You have a horizontal (y) deformation of 4mm. if you calculate with cracked concrete maybe 10mm.
admissible l/250 = 5500mm/250 = 22mm. I dont see the problem?
Kind regards,
Dennis van Dijk
Structural engineer
www.ibureaunoordwolde.nl
Victor_Huang1
Hi Dennisveendam
Thanks for the reply.
I was trying to use the SLS design and the "error" kept on showing up.
See attached.
          Regards;
Victor
DennisVDijk
Hi Victor,
You use the Australian concrete code, I think you can ignore the warning and make the check for allowable deflection yourself as an engineer. A I can see it is not possible to give in a deflection limit in "shell & Plate reinforcement type". The SLS-tab is not present in the menu, see screens:
Code: AS3600
Code: EuroCode EC2
furthermore the design options/possibilities and checks in RSA for concrete walls with reinforcement are limited.
If you go to "provided reinforcement" this message shows up.
Kind regards,
Dennis van Dijk
Structural engineer
Victor_Huang1
Hi Den,
Thanks for your help.
In addition, any idea of how we can set to calculate the long term deflection?
Regards;
Victor
DennisVDijk
Hello Victor,
You change the concrete E-modules, E-long term =  Eshort/3. Example C25/30 E = 28500Mpa Ecm = 9500Mpa, cracked/lond term:
Kind regards,
Dennis van Dijk
Structural engineer
