Tension only bars in compression under static wind pressure
Message 1 of 8
Good afternoon,
I'm currently working on a steel frame and tried to design my bracing element under wind loads.
I've modelized them as truss tensions bars and performed non-linear analysis but the results show me bars in compression only and/or inactive.
I've  defined my wind loads as static load cases.
I do not understand where is the problem?
Thanks for your help.
Replies (7)
Message 2 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
Has the analysis converged with no instability errors reported?
Artur Kosakowski
Message 3 of 8
Yes, I have couple of type 3 instabilities throughout the structure. But they so not seem to me as the roots of the problem. (see clip attached)
The separate structure is explained by the fact that I have a movement joints splitting the building in 3 parts.
Message 4 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may want to calculate each of the parts separately (in a separate file) for easier investigation of the cause of this situation. I wouldn't rule out the instabilities as the reason without checking this first. Is it the same if you delete releases from the model?
Artur Kosakowski
Message 5 of 8
I've removed all the releases and the results are the same.
I will try to slip the model on Monday and come back to you if necessary.
Thanks for your help and have a nice weekend.
Message 6 of 8
Good morning,
I've tried again this morning but this time I've selected the default setup (in compression only) and it works perfectly.
Is that a bug?Indeed, when you open the selection window
Indeed, when you open the selection window "Compressions bars" is selected by default but the sketch suggests tension. If you clic on tension or compression the sketch changes and displays an adequate picture.
Message 7 of 8
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm sorry but I'm not sure if I understand what you mean.
Artur Kosakowski
Message 8 of 8
Rafacascudo
Sorry to ask , but did you select all the bars you want to be "tension only" and then clicked to apply?
Rafael Medeiros
