Message 1 of 10
H all,
Please find attached the model I am working at. This is the tank under the hydrostatic load. Don't pay attention to the cover level that is smaller than recommended by the code.
Mxx map for panel number 2 and the corresponding calculation note for this model are attached as well. I don't know why in the calc note I don't see the extreme values of Mxx (also other forces) as per the map of Mxx.
Thank you in advance,
Jedi
@jedi.sznajder Artur Kosakowski edited the topic from 'Tank reinforcement' for better findability and marked one of the posts as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
