Take into consideration P-Delta effect
Hi guys,
I am calculating a 12-story building made of steel. Structural system is Special moment frame. According to the regulation of my country i need to take into consideration P-Δ effect. Could anyone advice me how to do that in RSA?
Hope you have a great week!
Cesar
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You can set it in this way:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Hi @Artur.Kosakowski
Should it be set for all load cases or just for dead load?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Usually all combinations.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Thank you my friend @Artur.Kosakowski
yesterday55555
I am curiously about this problem too, but I do not understand it clearly when I do analysis the structural witn P-delta
Should I do it with only load case or combinations ?
Could you please make a video about this problem ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @yesterday55555
You may find this page helpful:
Second Order Effects - A Beginner's Guide to Structural Engineering
Artur Kosakowski
