Surface load middle of plate
JPNR87
JPNR87
how is possible to addsurface load in the middle of plate? Blue on the picture is dwf xref.
Thanks!
JPNR87
Is only option to use Face/cladding option?
Muhammed.OPERA
Hi @JPNR87
You can make axes that contain the loaded area and use:
Surface load > Uniform planner load on contour, then the load value, the contour points ending with the first specified one, then add, then select the panel and apply.
Muhammed Mamdouh (OPERA)
Structural Engineer, Instructor
Facebook |LinkedIn
