Surface Geometry Import - Best Methods
EduardoMeruvia
Message 1 of 13
EduardoMeruvia
I have a 3D CAD surface model of a structure that I would like to import and analysis in Robot using Shell elements (See image below).
The geometry is not that complicated, but Robot seems unable to open/read the file AT ALL. I tried using a different set of files such as .SAT .IGS .DXF .STP but I ended up with the same result.
Is there a better and WORKING method to import "surface" geometry into Robot with more ease?
I'd appreciate any help. Thanks.
CAD file attached for reference.
Replies (12)
Message 2 of 13
Rafacascudo
I tried a lot to get it imported. No way with the native dwg. Exploding the panels/regions some multiple times ,I was able to import some bars but not enough to easily define the panels in Robot.
I tried also to mesh the panels in autocad before opening on Robot, as it seems it will work ,as described on a post answer.
But my autocad 3d knowledge is very limited and I could not produce any reasonable mesh. I am sorry.
As you said ,it is not so hard to do it in Robot from scratch ,but certainly it is obvious that RSA import feature is lacking functionality very much!!!
Rafael Medeiros
Message 3 of 13
EduardoMeruvia
Hi @Rafacascudo ,
Thanks for your reply. And yes, that is pretty much the conclusion I have arrived to myself.
@Rafal.Gaweda , @Artur.Kosakowski, apologies for dubbing you in, but would have any additional tips on this?
Appreciate your responses!
Message 4 of 13
Rafacascudo
 One thing that i have learned through all these years is that importing dwg/dwf will work well only if dwg is made of simple lines, if there are arcs, blocks,etc ,you have explode and turn them all into single lines
More and more complex shapes are coming to life.
Importing should be simple and easy for a wide range of formats. But for dwg it should be perfect!
Rafael Medeiros
Message 5 of 13
Romanich
Hi @EduardoMeruvia ,
I did my best. However, incoherent mesh still there:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 6 of 13
EduardoMeruvia
Hi @Romanich ,
Appreciate your response. You definitely got further than I did in getting more of the model across!
I ended up using Strand7 instead to complete the FEA analysis. Took about less than 5mins to get the geometry across and getting a compatible mesh. Hopefully Robot will soon include a similar functionality to its arsenal :D.
Message 7 of 13
Rafacascudo
Are you able to save this Strand Model(nice mesh!!) on dxf and open it in Robot?
Rafael Medeiros
Message 8 of 13
EduardoMeruvia
Your idea took us one step closer!
I was able to export meshed Strand7 model in to a DXF, and then import/open that directly in to Robot. With Robot's standard settings, the DXF came across as "BAR" elements i.e. it broke down all the meshed surface components into a small square frames formed by bar elements, see image below.
Changing the import settings so to convert surfaces to QUAD4 or QUAD8 meshes, allowed me to actually bring the mesh as MESH. However, the panel component that encases the mesh has to be place manually by selecting the all the corresponding "MESH" components and then assigning it a panel thickness/property (see image below, base plate panel assigned to all MESH FEA component of the base plate).
From that quick exercise, I think you can follow that process, and manually select the MESH components corresponding to the Pipe, Stiffners, End PLates, etc. and then assign the panel property as required. Still some decent manual "cleaning up" processing from the user end, but at least it seems you will get a model with a compatible mesh that should work for your analysis.
Exported DXF file for your reference if you feel like giving it a try on your end.
Message 9 of 13
Rafacascudo
That was exactly what I was planning to do when I suggested the dxf conversion. Well done!!!
But being autocad and Robot ,both from Autodesk , the conversion should be easy and flawless!!
Maybe @Krzysztof_Wasik  can show us an easier way to do it!
Rafael Medeiros
Message 10 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Rafacascudo @EduardoMeruvia @Romanich
I have checked the following workflow.
I have opened DWG file in Fusion 360 then saved file in SAt format.
Then Model could be imported to Robot
Panels was created using geometrical objects.
Model was meshed and calculated (no incoherences)
Some final tuning regarding panel ,local axes are necessary (and possible) and some additional work on small openings (also possible)
I hope it could help
Krzysztof Wasik
Message 11 of 13
EduardoMeruvia
Hi @Krzysztof_Wasik
Thank you for your reply.
Just one question, I tried following your method and I seem to manage to get the .SAT file (exported from fusion 360) in to Robot. But once in Robot when I assigned a panel thickness to them and try to mesh them, they produce an incoherent mesh. See image below.
Applying thickness to panelsApplying thickness to panelsIncoherent Mesh at IntersectionsIncoherent Mesh at Intersections
When you said you created your panels using the "geometrical Objects" could shown me how did you do that step?
Appreciate your help.
Message 12 of 13
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @EduardoMeruvia
It is not my best video but I hope it shows the idea quit clearly
SAT file Meshing
Krzysztof Wasik
Message 13 of 13
EduardoMeruvia
HI @Krzysztof_Wasik ,
Appreciate your time and Thank you for your video!
It is a good workaround to get the desired geometry in Robot. I'll keep that in mind next time I'm trying to import something "complex" directly.
Cheers!
