Supports generating themselves
jchristianG86XJ
jchristianG86XJ
I have a model where when I click calculate, roller supports are appearing themselves in an area where there were some that were deleted.
A friend advised this was because the base level was -0.2m but defined in Robot as 0.0m I changed the base level and this worked, but then the file corrupted so i had to open it from a backup and now the exact same solution is not working.
I have attached the model. The roller supports that I do not want are appearing at 0,0,0 and 15.8,0,0.
I have tried also deleting these supports from the table view, to no avail.
Joe
Simau
There is no model attached.
Zip the model before attaching
M. Agayr
jchristianG86XJ
Apologies, attached.
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @jchristianG86XJ
Delete linear support from bottom edge of cladding 22
Krzysztof Wasik
jchristianG86XJ
Great, thank you. I don't know how i missed that.
