Support Reaction at ULS Group load combinations
Message 1 of 11
I have defined 10 load combinations, 8-ULS and 2-SLS.
I have grouped the ULS under the name of ULS groups and the same for SLS groups.
When I want to see the reactions at support for a given load combination, the result appears clearly !!
When I want to see the maximum results, the I use the ULS group !! but the result is not for the maximum !!
Moreover, the shape of rxns appear, but the description is not !!
Please check attached screen shots.
Thanks in advance for help.
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Message 3 of 11
Dear,
Please find attached file.
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is wat I see:
Rafal Gaweda
Message 5 of 11
Also this is what I see,
But ULS Groups is governing the ULS combinations, Cases from 6 to 13.
What about other combinations ?? (Comb1, Comb2, Comb3, ....., Comb 13) that gives higher values !!
Where is Fz ?? and Mz ??
Note: In other projects it works properly, but I donot know why in this project, it is not giving the descriptions.
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example results in node 3
(The rest of results check by your own)
Rafal Gaweda
Message 7 of 11
The problem is the description is not showing all the reactions. I mean in my model it is showing reactions only for Fy and Fx.
Then in your Model (Screen shot) Mz appears, I donot know how you fix it and make it appear.
Fz still not existing. (Knowing that I am selection all rxns with description)
Message 8 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 9 of 11
I Know how to check the maximum values, this is not my problem.
The problem is the rxns are not displayed in the diagram ??
Please check the screen shot that I have send, and yoy can see that Fz and Mz are not displayed in the diagram.
Therefore how to make Fz and Mz appear in the diagram.
Message 10 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Update your robot with the latest SP
Clear cfgusr folder
Open file in rapair mode
Rafal Gaweda
Message 11 of 11
The Problem is solved.
Thanks for help.
