Add function
Add function
Ludwigswe
Message 1 of 8
Add function
Ludwigswe
Hello!
I have data in excel that I would like to use to define a Non-linear model (Compatible nodes) in Robot!
How to do that?
Regards
Ludwig
Replies (7)
Message 2 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
Either I do not understand you or you are looking for API code.
Example:
http://forums.autodesk.com/t5/robot-structural-analysis/api-moment-capacity-curve-via-api-nonlinear-...
Rafal Gaweda
Message 3 of 8
Ludwigswe
Sorry for being Unclear into Describing the issue!
I would like to put xy data (Force-displacement) Into the Non-linear definition, to define an elastic compatible node!
[cid:image001.png@01D02E5C.95797BA0]
Regards
Ludwig Lundberg
Structural Engineer
Bridge- & Plant Design
ÅF, Infrastructure AB
Visiting address: Kvarnbergsgatan 2 | Postal address: P.O. Box 1551, SE-401 51 Göteborg
Direct: +46 (0)10-505 47 67 | Mobile: +46 (0)76-772 43 56 ludwig.lundberg@afconsult.com | www.afconsult.com
Message 4 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
What is the problem then?
(Screen capture missing)
Rafal Gaweda
Message 5 of 8
Ludwigswe
Message 6 of 8
Ludwigswe
File format for in data?
Message 7 of 8
Ludwigswe
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
If you press diskette button you will know everything
Save xls to csv and them adjust it to Robot needs.
Rafal Gaweda
